Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
rake & trail
Old 11-02-2018, 08:12 PM
talkingrock's Avatar
talkingrock
talkingrock is offline
Default Lift
Originally Posted by DK Custom
Legends does not make a Comfort Lift™ Kit. They make a standard lift kit that does not provide the additional shock angle to make the ride more plush.
We used to make a Standard Lift and a Comfort Lift™ , but have discontinued the standard. The Comfort Lift™ Kit is does everything the standard does and more. Link to details HERE.
Regarding the discussion of Rake & Trail. It can be a bit intimidating when first trying to understand it all, but there is a really good article at this LINK, by Mark Zimmerman, that gives all the technical info, but in fairly clear "English".
call it what you want sir but it improved the ride and handling
Old 11-02-2018, 09:08 PM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,930 Likes on 2,288 Posts
Oh, absolutely. Any Lift Kit is going to improve the ride and handling...also give the exhaust better clearance...no doubt about that.
No offense was intended. Just wanted to avoid any confusion.
The Comfort Lift is a DK Custom Products Trademark of the DK Lift Kit that has the same features as many other companies that make Lift Kits, Plus it has the added benefit of changing the angle of the shock for increased leverage, resulting in an even plusher ride quality.
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Old 11-02-2018, 09:14 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,201 Likes on 11,127 Posts
Originally Posted by Helmwurst
If your trike is squatting in the rear, like most of the earlier ones did, try adding a pair of adjustable or air shocks to the rear and raise it up level. This will improve the steering.
that has nothing to do with the topic. So, carry on.
Scratchandsave4abike
09-09-2021 02:34 AM
pettifogger1
11-01-2012 11:33 AM
ultrapawpaw
11-24-2011 08:54 AM
HDDYNA
02-18-2009 04:26 PM
Swamphunter
09-02-2007 09:18 PM
Quick Reply: rake & trail
