Reverse motor failure!!!
I opted for Champion reverse. My bud is on his third reverse motor on a 09 trike. I never used my reverse since I bought an 09 used in 5/13. Had an 08 Ultra with a hack and never seen the need for reverse, my wife was reverse. Old age creeps in quickly so I relented to the Champion unit with the urging of my wife. It's a godsend in the right situation and at a little over $1800 installed should be once and done. Works real slick.
dan
dan
++ on the mechanical reverse if the electric reverse goes on my TG. I currently have the MotorTrike's reverse on my SG. I am 62 and too old pushing the bike backward. I have not used it too often, but it is there if I need it. I went with the MotorTrike over the Champion, since MotorTrike has a kill switch that kills the engine if you happen to have the tranny in reverse and 1st gear at the same time.
My friend has a 2011 Tri and had a problem with his reverse. Found out from the dealer today that the motor went out. They will replace it under warranty. I thought I was brousing some forum and read where there was a problem with some of these motors. Am I remembering right? And have they improved or corrected the problem? Gee, see these motors are like 1400 bucks if I remember correctly.
Body removed.
Reverse motor. Brushes are under the black cap.
The stuck brushes. Notice how short they are compared to the other two.
Off of eBay. Delivered in 3 days.
Off of eBay. Actually there was a discount and it was $20 delivered. Said 4 day delivery but got them in 2.
