Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri-Glide Reverse
Old 08-04-2013, 06:31 PM
JimmyT1950's Avatar
JimmyT1950
JimmyT1950 is offline
Default Tri-Glide Reverse
I purchased a 110th anniversary trike and it has reverse. My question is this. Is there a separate electric motor for reverse or does reverse use the starter motor? I have been told both.
Old 08-04-2013, 06:37 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
It has a seperate reverse motor. Pretty costly if I remember correctly. Hondas use the starter motor if my facts are correct. Go to the trike section for tons of good info.
Old 08-04-2013, 06:47 PM
Delta's Avatar
Delta
Delta is offline
It has a separate motor.
Old 08-04-2013, 07:12 PM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
Your facts are correct. The motor is very expensive, $1,500. If mine ever goes I will put in a mechanical one,
Old 08-04-2013, 08:11 PM
acunn1's Avatar
acunn1
acunn1 is offline
I was also told it uses the starter motor
Old 08-04-2013, 09:08 PM
JimmyT1950's Avatar
JimmyT1950
Thanks for all the responses!!!
Old 08-04-2013, 09:14 PM
PIGGI's Avatar
PIGGI
PIGGI is offline
Take the right side cover off and look back under the box and you can see it sitting on top of the rear pulley.
Old 08-04-2013, 10:14 PM
TimAT's Avatar
TimAT
TimAT is offline
Its a motor that drives a larger ring gear on the rear axle. It does "look" like a starter motor, but that's all. The engine starter sets in the usual place between the engine and trans.
Old 08-05-2013, 09:42 AM
BinIdaho's Avatar
BinIdaho
BinIdaho is offline
10 toes is the "new" mechanical reverse motor Mike!
Old 08-05-2013, 10:05 AM
Ga Blue Knight's Avatar
Ga Blue Knight
Ga Blue Knight is offline
Or park up hill!
Quick Reply: Tri-Glide Reverse
