What did you do to Your Tri-Glide Today?
#1291
#1292
Received 3,941 Likes
Got my zerk fittings in...
...going to be installing on my primary case for the shifter shaft. Used to have these on all my bikes, but in the last 10 years or so have not, nor have I felt the need.
However, on my '14 TG it is getting a bit loose. Not sure why, but going to fix it.
#1293
I think I have the problem solved. The trike had been sitting for some months before I bought it. I jacked up one side to get under it to tighten the reverse motor. When I let it down, it wouldn't stay running for more than one sec. The HD wrench said that the tilt mechanism that moves when bike is laid down was corroded and moved enough to indicate a tilt. Then it wouldn't go back. Had to order another box. Hopefully it will fix the problem
Muffbrorick (11-30-2017)
#1297
Dmdrone (12-04-2017)
#1298
Rode it ............... In the rain, but at least it got ridden. This has been a mild winter in my part of TX. Sadly, our morning temps have been in the lower 50* to 40* range at sun up when I must leave for ride to work. Sucks when the temps go to the mid 70* mark at mid day. By the time I leave work it's dark and the temps have dropped drastically.
