Tri-Glide Issues-2014 Trikes And Newer Rushmore Trikes
#221
Gary
Thanks for the reply and info.. I guess I jumped the gun on looking for a DECENT price for the lift kit.. for a price of $60.00 that is way cooler than the $200.00 I keep seeing.. I just couldn't justify the price.. I know what it takes to design and market different things as I work in a steel fab shop.. and I wasn't trying to be cheap about it.. (especially after what I paid for a Tri Glide ) but you have to save where you can at my age ( over the 60 mark ) and the high price just does not seem worth the cost for what they are..
#222
Loud shifting
Since purchasing our TG in 2014, new, I've been complaining about the noise when I shift. Non HD friends always ask if there is something wrong but the dealer is no help. This year I took by TG to a local Motorcycle service outlet who told me that HD is the only motor vehicle manufacturer who specified engine oil for their transitions. He replace my engine oil that was in the transition with actual TRANSMITION FLUID and wa-laa, I can barely hear the damn thing shift. I'm sold. No idea why HD cannot figure this out.
#223
3 different applications = 3 different fluids.
I use Amsoil (preferably) or any brand name 20-50 syn motorcycle oil in the engine. (10-40 in the winter)
Amsoil 75-110 Severe Gear oil in the trans
H-D Formula+ in the primary.
#224
#225
My 2016 has 1100 miles on it. At 900 miles the Check Engine And Overheat lights came on. After a couple of visits the dealer replaced the Thermostat. That was three weeks ago. Yesterday started it up and they came on before the bike was even really warmed up (fans hadn’t even kicked on, and at no time has the bottle burped). So now I have to take it back and I guess I’ll ask for a pump replacement. Not sure what else could cause the lights coming on.
#227
Along with hundreds of other riders that put the same oil in all 3 holes....because Harley says so.
"3 different applications = 3 different fluids." absolutely
#228
Ok, follow up to my entry in Nov. of 2017. Took it back to my favorite Harley dealership and we had a head banging session. Came out of it with the idea that the pump was really working fine so that couldn’t be the problem. So, Harley paid to have the two Heat Sensors changed out and (cross your fingers and what ever other parts you like to play with) it seems to have taken care of the problem. As for the Amsoil line above - I put Amsoil down all the holes - and it shifts better and seems to run smoother. So, as soon as this winter snap gets it’s ugly *** out of here we’re gonna do some riding!
#229
I know what you mean by &*$#* weather Ohio here.. I am looking for the Amsoil 75 110 severe but in this town its hard to find.. like anything else probably have to order it from somewhere.. I used Castrol 20/50 Syn motor oil in my SuperGlide .. really like it... going to use it in my Tri Glide..still thinking about the lift kit for T/G but I still got time for that.. thanks to everyone on here glad there is a place to find out about different things on Harleys
#230
I ended up ordering all my Amsoil products direct from Amsoil. Comes super fast - price is good. If you join their membership thingy you get a percentage off all orders. As for the lift kit - I was looking at that - then was reading that it would change the steering dynamics of the Trike, possibly enough that you will have to have the front end recalibrated and balanced out. I can understand the issue as there is so much weight on that Trike it has to be carefully balanced Front and rear. A “heavy” 2-wheeler might weigh in at 850 to 1000 pounds, but the Trike runs about 1400-1600 wet without the rider. They put a lot of that weight on the rear end for good reason.
