Just took out my new Trike, forks seem loose
While riding the side streets and getting familiar with the new Trike, It felt like the front end was wobley or forks loose or front tire.? Maybe it was the road with pot holes etc. or just me. I will check the front end for tightness. I would hate to be going down the road at 50 mph and have this wobble. Another thing was these things don't go slow. Coming out of first gear, seems like after the clutch was out, I was moving over 15 mph. When letting out the clutch, the engine would almost die, so I had to give more throttle. The left side of the gear case, I guess it is called the primary chain case, sounded like something was banging around. I hate to prejudge this thing, I know Harleys were known for not being quit or smooth like a bmw, but I guess I will run it through the paces for awhile. Let me know what you guys think about your Trikes. Would help to give me some peace of mind.
Thanks, No ball breaking , but I can take it.
Al
Al
Al
Al
Yes, first gear winds out pretty fast. In fact, be careful twisting the throttle in first gear on tight turns. Learned this the hard way as the weight comes off the font tire and it can easily break loose.
The engine top end can kind of sound like an old Singer sewing machine. But, it does not seem normal to have a clinking around sound coming from the primary.
Sounds lie a visit to your dealer is in order.
As for the sound at the chain case. Hard to tell without hearing it, but is it the same when just starting out cold? The reason I ask is as the lube warms you will hear more sound, but there have been some chain tensioner piston sticks. Before I took delivery of my 13, the dealer had to tear down and replace the pistons. I never even heard the sound, but they said it was obvious to them the tensioner piston had not returned causing chain slap. Of coarse then I was thinking I always heard something until I realized when cold, it was quiet, then as it warmed up it had the normal sound of a Harley. I rode 2 other Tri-Glides to convince myself. If it make same sound at cold, take it to the dealer and ensure they investigate chain tensioners.
The compensator has the latest style, not the same as the earlier TG versions. Primary chain slap could be due to the new tensioner. It is spring loaded with a set of saw teeth. The more you get on and off the gas the more the tensioner adjusts up to the next tooth. That's the tensioner in the center of the picture.
Once you get more miles on the TG and adjust how to ride it you will have a few funny noises go away.
Don't be shy... keep the throttle up. As said above, if the motor wants to die then you need more throttle. They don't like anything under 2000 RPM's. 2500 is a decent cruising range and 3000 will be her sweat spot. Shift at 4000 in lower gears until you get to speed. This is good for the break in period. After that your shifting RPM's will become second nature.
If you feel the front end as still loose after you get 500 miles on her then visit the dealer with the complaint. No need to be nervous about the TG.. She's heavy and tough and likes to be man handled.
This upgrade will not be an upgrade option for the earlier years since the neck on the frame is also different.
Al
Al
Thanks for input, I have big feet
It all makes sense, went out today and got some miles and 2000 is max when breaking in for 500 miles. Easy to hit 3K. Runs and feels great at 2000 rpms. 1st gear will keep me around 15 mph or so.
I have size 13 boots and keep missing the shifter and have to point inward and back to not hit the fairing, also hit fairing on right side and almost missed a stop because I pressed on the lower portion of the fairing. Having trouble with finding the sweet spot for my foot so I can press on the brake pedal. I will have to get that with practice. Another 4 to 8 hours at least, I think I will feel comfortable on the bike. I just don't like people riding on my ***. 2 times I GOT ON IT BECAUSE I FELT I WAS HOLDING BACK TRAFFIC BUT I WAS IN A RESIDENTIAL AND FELT 25 30 WAS OK, BUT SOME PEOPLE JUST LIKE TO PUSH YOU. oN THE OTHER HAND MAYBE THEY WANT to see a close up of my Trike.
