Another Cam thread
#351
#352
Mr. Wizard (12-18-2018)
#353
Cam help
K so here it goes I spend most my time above 3 grand due to I heard anything under that is ******* it and bad for your cam chains.i hit the rev limit on most gears until about 4th I have the powe commander v anda dan moto 2 into 1 I also ride double up sometimes. So which cam is recommended please help thank you in advance.
2016 street bob 103 with PCV and Danmoto 2 into 1
#354
You still want to know what cams work best. For me it is the TTS100. Second place for a TriGlide is the Andrews 57H. But... Find someone in your area that can tune using the PCV or any cam work will be wasted.
Oh.. if you want your user name changed to something else besides your email address let me know. People usually don't use email for ID here.
#355
Thank you
Mr. Wizard thank you for your response. I will definitely consider everything you mentioned. I think I posted this in the wrong forum though I didnt realize it was for tri glides.
I should probably take the email part off haha I didt even realize. I am fairly new to the forum thing.
#356
In about 10 minutes I'm going to change your user name to RDowns2016
#358
Another CAM thread
Anyone use the H.D. MoCo SE8-447 TORQUE CAM with the Stage III upgrade instead of the SE8-498 POWER CAM. The Torque Curve with the 447 so much better fits my riding style and Trike loading than does the 498 Horse Power RPM curve. My dealership Service Advisor feels the 498 is better. However, I am not a Freeway Highspeed High RPM driver. On my last Bike with Stage III had a 255 Torque CAM and the combination was great.
Looking for your thoughts or experience.
Gary
Gary
#359
Gary
Gary
That being the needed objective look for a cam that starts out as low an rpm as you can get. Not that you will be utilizing the big gain below 2000RPM, but the torque needs to be available for the lower ranges when you demand it and not just in the mid to upper RPM ranges. TTS also makes a good cam for the M8's, from what I have read. Worth a good look.
Another thing to look at is the problem with pinging many big cams cause. That 225 cam has that problem. Very picky on the tune and gas ! It also fell on its face in the upper RPM's.
Mr. Wizard (12-21-2018)
