volume control rear
hey guys I just importrd a 2012 trike into australia and having trouble with the rear volume adjuster for speakers
can anyone tell me if this is suppost to work to adjust the radio volume from the passanger seat thanks |
If you are trying to adjust the rear speaker volume at the rear speaker pod, you will not be able to. That volume control is for the passenger push to talk. Head set control. Did you get a manual with the trike? Read up on audio. You can adjust the rear speaker volume by pushing the left handlebar volume control repeat until stereo shows fade, then increase for more front, or decrease for more rear.
The volume control only works when a headset is plugged in for passenger !
© 2024 MH Sub I, LLC dba Internet Brands
