2018 Breakout
I got some V&H Bigshots of an '10 Wideglide for cheap. These had the flat style gasket and the '18 models have a tapered gasket. Had to dig out the new ones and put the flat style in the ports. Had to get some reducers for the O2 sensors. The rear header needed to be moved rearwards about 10mm (3/8"). I just cut it - not all the way through and bent it slightly. Tried the fit and re welded it. Still fitted inside the heat shield. Next made a bracket using original holes and incorporated the foot peg mount. I have ended up removing the baffles as it was still a bit quiet. About 3 hrs work all up.
Jack Straw
02-27-2017 10:18 AM
