VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Replace battery and plugs.
Old 04-29-2017, 04:29 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Default Replace battery and plugs.
Had to replace the battery in my 12 NRS. It really takes some digging and parts removal.
However it was time for new plugs so I took care of that at the same time. The coil over the plugs boot was frozen to the plugs. I thought they would tear off but got them out okay.
From start to finish it took me 4 hours. Since it was the first time I think the next time would take a lot less time.
It has been raining every day all day so I haven't been able to get it on the road to see how it runs now.
Old 04-29-2017, 08:42 PM
Hal64hd's Avatar
Hal64hd
Hal64hd is offline
Make sure to use dielectric grease on the boots, and they won't sick to the plugs
Spy11 (05-05-2017)
Old 05-01-2017, 08:07 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Got it out today between rains and that sucker ran beautiful. There was less than 7K on the plugs but they were bad. Installed iridium plugs.
Old 05-05-2017, 04:30 PM
Hal64hd's Avatar
Hal64hd
Hal64hd is offline
Be careful, Iridium plugs tend to mess with the ION sensing systems and messes with the ignition timing. I use the Factory Double Platinum Spark plugs to be safe seeing how they have the same resistance as the copper core and last much longer
Old 05-13-2017, 11:57 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
"Be careful, Iridium plugs tend to mess with the ION sensing systems and messes with the ignition timing. I use the Factory Double Platinum Spark plugs to be safe seeing how they have the same resistance as the copper core and last much longer"
100% internet BS. First the iridium plug is spec'ed for the HD engine resistance requirement. And NO plug has anything to do with engine timing in any way shape or form.
The ion sensing only measures total resistance and the plug has the same amount of resistance so it does not add or reduce the level of resistance that triggers the ecm to retard the spark.
All an iridium plug does is provide a more concentrated spark and is the best choice for E10 gas. It is self cleaning. Those two factors are why most new cars of most makers come standard with iridium plugs like Toyota and others. The platinum plug is close in performance but not quite to the level of iridium which the wire is harder and smaller in diameter than the platinum.
Sportsters and M8's do not use ion sensing systems. The M8 does use a microphone.
I only use iridium plugs in all my bikes which includes every H-D motor from the 80 inch Evo, the Sportster 883 and 1200, the Street XG750 and Street Rod XG750A, TC 88-96-103-103 HO-110-120 ST-120R, V-Rod 1250 and a M8 107. That use includes over 400K combined miles on them. So tell me that iridiums don't work.
05-01-2016 07:18 PM
adwalker67
01-13-2013 10:47 AM
RidemyEVO
EVO
38
02-08-2011 11:47 AM
biker_chick
07-05-2010 09:41 AM
cws176
08-17-2007 12:07 AM
Quick Reply: Replace battery and plugs.
