Fatboy/Heritage front wheel or similar on a Deuce?
Considerations:
*Wheel and rotor spacing (may be the same, haven't confirmed)
*I would also keep an eye on those Deuce fender brackets...they may or may not clear that 130 tire...dunno (or are you going to change the fender too?)
But someone who has done this exactly may chime in (as you had asked).
Why not?...have a party
Considerations:
Considerations:
I think the brackets might be close, but i was going to modify my current fender to clear the new wheel.
Hopefully someone on here has done this modification before. Anybody..........................????
I hesitated to say earlier although i thought it to be the case, 2000-2006 Deuce and Heritage...same part#...same hub. Pretty sure 2007 (last year Deuce, first year 25mm bearing) Deuce and Heritage are the same also respectively.
The wheel in this case has always been the easy part. I'd focus on the fender to tire situation.
good luck
good luck
good luck
good luck
But since it's a bit further down the chain on my "to do list", don't hold your breath on the updates lol
