140 or 130 rear tire size recomend for 81 FXWG?
The 140/90 will also be a little larger in diameter. Some tyre brands do an MU or equivalent, which is 140/85 and pretty well the same diameter as the stock MT.
Before you spend your money however check your current tyre to belt/guard clearance. On my 1990 Glide I had to trim the rubber part of the belt guard and only had 3/16" total clearance. Unfortunately installed width can vary from the nominal size (my 140/90 was only 139mm wide, but others are reported as being wider) and also differs from brand to brand.
