06-08 flhx rims
Are the 16 x 3 rims that come stock on these bikes the same front and rear? Can I run a front rim in the rear?
I wrecked my rear rim, I can buy a 16 x 3 front rim cheap. Will it work? Is the front rim the same? Yes I will be putting the rear rotor, cush drive, and rear tire on it. Anyone? Trying to buy today.
Originally Posted by LUBA
(Post 14092472)
Well...not without machine work that's wasted on a 16" wheel (because Rears are available). On a 18" rim...that's a different story. Rear Has: - Slightly wider hub - Different bolt sizes for both pulley and rotor - Offset (hub isn't centered within wheel) You know why 16" Front Airstrikes are relatively cheap?...because very few people want them...they are undesireable. |
Yes you did thanks, I almost pulled the trigger on a cheap front to run in the rear, Thanks again. Now I just have to decide if I want to invest the money in a stock rear or just upgrade to aftermarket bigger chrome wheels front and rear.
© 2024 MH Sub I, LLC dba Internet Brands
