cant get bead on tire after changing tire
some to consider;
make sure the core is out of valve stem (reduce restriction).
try to elevate the wheel if one side will seat then you can push/pull the other side tight.
use rope or come-along to cinch the crown of tire, making the section width bigger.
Haven't tried this on a bike tire but have used starting fluid to ignite, the blast will seat everything from a tractor tire to a 4 wheeler...
fingers crossed
fingers crossed
How many PSI are you using on your compressor. You need quite a bit of pressure to seat a stubborn bead. I've used carb cleaner and a lighter on a 33" mud tire, but not on a motorcycle tire. That's pretty dangerous.
Try a ratchet strap around the circumference of the tire. I've used Windex on the part that doesn't want to seat to help it slide. Those are some of the tricks that I've tried. There's a lot of videos on youtube. Good luck
Received 4,614 Likes
A standard air chuck with the center pin to depress the valve in the stem doesn't pass much air. If you don't have a free flow chuck (requires the valve to be removed to work), you can unscrew the center pin to get more air volume. I took a cheap chuck, and drilled it out larger with the pin out, makes a big difference seating beads. The ratchet strap trick works pretty good, but stop putting air in as soon as the bead seats, and let the air out again, makes it much easier to get the strap loose. Let the compressor run till it shuts off (max pressure), then air the tire. Those cheap 100-120 psi 2hp compressors with small tanks just won't do it sometimes. I got a 200 psi compressor, and it made a world of difference.
A lot of tires come wrapped tight with plastic, and take a set with the beads almost touching. You can put some 1 qt oil containers sideway in them overnight (2x4s, anything that will hold them apart) and they'll expand easier.
I used to fit all my own tyres in the good ole days, however I eventually gave up with tubeless ones, partly due to this very problem, but also they are bigger and stiffer these days. If you have to then visit a tyre depot, where they will have the air capacity to blast your beads onto the rim.
some to consider;
fingers crossed
fingers crossed
