23 Inch Wheel and Fender ?
Hello everyone I am attempting to put a 23 inch 1 inch axle wheel that I got for cheap on my wide glide front end. Also looking for the right fender so I have a few questions for you guys.
1) what wrap around fender did you use. Do you have the link to buy it and maybe a picture
2) did you have to modify your fender
3) what is your measurement from the center of the axle to the fork fender mount
4) does anyone know the width of your one inch axle at both ends? Looking to find an axle that will fit my wide glide front end but also my 1 inch bearings my front end is originally a 3/4 inch axle.
I actually found a bearing adapter that allows you to use the 3/4 axle with the 1 inch wheel bearings. Here is the link http://vulcanworks.net/store/Wheel-Bearing-Adapter-Kit-1-to-3-4.html has anyone had any experience with these? I also am going to contact Russ Wernimont for a possible front wrap fender but still want to know if anyone has any ideas for a front fender?
Hogpro
08-02-2013 12:00 AM
lp77
07-08-2012 03:47 AM
