200mm tire question
Tolerances are one thing but could Avon have really made fundamental changes to a tire model without changing its model ID in some way ? I'm asking because I'd like to know. I, like many others, run an outsized rear tire on my Breakout and would look askance at the current possibility of buying an Avon 250 if this were the case.
Thanx
Thanx
Whatever brand we buy when fitting over-sized tyres we run the same risk! It would be an interesting excercise to try the same size tyre from the leading brands on the same wheel rim, to measure the variations across them. The Cobra 250 is described as being 251mm wide - reasonably close!
HKMark23 (06-05-2017)
