05 Heritage loose spokes
He came up with a mag type wheel that he was told was a direct fit. We decided to mach fit it tonight. The axel size is correct, rotor bolts on fine. sprocket/ pulley bolts on fine. The only thing that I see, is the raised up place on the wheel where the center hole of the sprocket/ pulley goes is slightly smaller than the original spoke wheel. In other words, The big center hole in the sprocket / pulley has about 1/16"the all the way around between the hole and the raised area. Thoughts
It wouldn't be considered a "Direct Fit"
That's a 1999-earlier Tapered Roller Bearing wheel with smaller pulley/rotor locators. 2000-later wheels used sealed ball bearings with larger pulley/rotor locators .
Are you sure the Wheel spacers are passing through the grease seals and contacting the inner bearing race with proper spacing?
http://vulcanworks.net/store/Harley-...pter-Ring.html
If you get the spacing worked out OK and want to stay with that wheel, then you could use these...
I'd take a hard look at your spacing and total "stack-up" width compared to the original.
Also typically tapered wheel bearings with SEPARATE seals run 3 spacers. 2 that are short and usually the same size just get you out past the seals (and provide a good O.D. sealing surface for the seals), and then the 3rd to complete the spacing on the pulley side.
We finally got back on this project. The Vulcan engineering adapter spacers made it all work out correctly. We put new bearings in it added the adapter spacers. Took it for a 100 mile stroll yesterday. Thanks to everyone for their input. I'd never knew about those adapter rings without this post.
