Wheel compatible between 2006 Sportster rear wheel and 2015 Forty-Eight(XL1200X) Front wheel??
Hello, Im a new menber who live in korea have 2015 Forty-Eight
I want to cange my Forty-Eight wheel to casting Wheel.
Could 2006 Sportster rear wheel and 2015 Forty-Eight(XL1200X) Front wheel??
and also 2006 Sportster rear wheel and 2015 Forty-Eight(XL1200X) rear wheel??
This is 2006 Sportster rear wheel that I want to use for 2015 Forty-Eight(XL1200X) Front wheel
This is 2006 Sportster rear wheel that I want to use for 2015 Forty-Eight(XL1200X) rear wheel
Thank you~ and have a good day
Putting the 2006 REAR on the Rear of 2015 48 will be straight forward. You need an "installation kit" (or buy the bearing shim and spacer sleeve separately) for the 48 REAR.
Using a REAR wheel for a Front can be done, but they're are obstacles. One of which is the Rear Hub is wider (it's like a wideglide) than your 48 midglide hub/forks.
