Longer rotor to hub bolts?
Old 07-30-2017, 03:04 PM
Eagle Keeper's Avatar
Eagle Keeper
Eagle Keeper is offline
Default Longer rotor to hub bolts?
Has anyone found alternate lengths of the OEM rotor bolts?
On my 07 Softail I changed front wheels and changed axle spacers to move RH .250" to center wheel, then added .250" spacer behind rotor to align with caliper. The rotor bolts are too short (5/16-18 x 7/8).
I've tried alternate types of bolts but the heads are too small or too big for the recessed flange holes of the rotor. The stock button head is larger diameter than standard bolts and fits snug in the hole to help center and maintain torque.
It seemed simple at first to find longer same style bolts. I didn't want to try washers on smaller head bolts and make balance worse or worry about loss of torque.
Thanks for any input. Sure would like to be riding instead of typing.
Old 09-02-2017, 05:25 PM
Eagle Keeper
Disregard. I found out these stock bolts aren't made longer. I was hoping they were more common and used somewhere else in longer length. I used some flange bolts from bolts depot, cut them to length and ground the head to fit just right. Any other type I found that was long enough had half inch diameter head which was too small for a brake rotor.
Old 09-02-2017, 09:50 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
are they grade 5 or grade 8? I used some grade 8 when I added a spacer, you can get covers to clean the look up.
Old 09-02-2017, 10:40 PM
Eagle Keeper
They are grade 8, nice looking quality and came with threadlocker. I got both stainless and chrome and used the stainless along with caps. They fit just right and look better than the stock ones once I put the caps on them.
Old 09-16-2017, 03:03 PM
Almond farmer's Avatar
Almond farmer
Almond farmer is offline
Try "Albany County Fasteners".
This a speciality fasteners manufacturer
pan head torx head , 5/16-18 x 1-1/4" length
318 stainless steel
Head diameter tolerance spec .615"-.564"
Measured an H-D rotor torx head bolt, head diameter measures, .600".
The Albany fastener will fit the rotor mounting hole recess
These fasteners can be ordered online
You ask for an alternate front rotor fastener that looks OEM, you have it now.
Grade 8 has greater yield strength than 18-8 stainless steel
But the fasteners are in shear with amble strength to handle the brake caliper torque
Load.
The aluminum hub threads are the weak link
oakspeed
2014-2023 Touring Models
11-24-2015 10:35 AM
mastery
08-09-2015 11:21 AM
Kev_England
11-18-2010 03:05 PM
1Reaper
05-16-2009 04:38 PM
cwickgo9
03-27-2008 04:28 PM
Quick Reply: Longer rotor to hub bolts?
