Wire Spoke Front Wheel to suit 2014 FXSB Breakout
Old 10-19-2017, 08:27 PM
Chaymus72's Avatar
Chaymus72
Chaymus72 is offline
Stage I
Default Wire Spoke Front Wheel to suit 2014 FXSB Breakout
Hi all,
Does anyone know where to get a 21 x 2.15 40 or 60 spoke rim to suit a 2014 FXSB with ABS?
Cheers
Chaymus
Old 10-26-2017, 11:28 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Hi from the UK and welcome to HDF. If you're looking to the US market to supply we have several HDF sponsors who can supply wheels, possibly at discount. Take a look at the Vendor Directory, via the thin blue bar above. Tell them you are a member of HDF!
Old 12-05-2017, 03:15 PM
Blackp5ca's Avatar
Blackp5ca
Blackp5ca is offline
A front rim from a Softail Blackline or Dyna Wide Glide with ABS would work, they are both 21 x 2.15 and 40 spoke with the required 25mm bearings. The breakout is a wide glide front end as is the Blackline (and Dyna wide glide obviously) I would assume the wheel spacers would be fine from your breakout as the hubs are typically the same dimensionally.
Blackline is a black smooth hoop and black hub, Dyna WG is a black stepped hoop and chrome/polished hub. Take your pic if you're trying to match to rear rim.
SlimFan
12-07-2015 06:33 PM
COCHO
10-17-2013 08:28 PM
DE Rocker
01-07-2011 12:14 AM
manofsteele2003
05-22-2009 08:58 AM
TMace
03-18-2008 06:02 PM
Quick Reply: Wire Spoke Front Wheel to suit 2014 FXSB Breakout
