2007 road king cvo front rim swap
I have a 2007 road king cvo non abs with the 18in front factory wheel. the chrome is starting to peel so I'm wanting to go to a 19in enforcer wheel off a 2016 SG. im pretty sure I will need to change the newer larger brake calipers, rotors, and change the bearing to a non abs bearing. is there anything else that I will need to consider when doing this or is there a better way this can be done? not sure about the axle either. the wheel.in the picture is the rim currently on my bike.
