'98 FXSTS Front tire
Old 12-07-2017, 12:05 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Default '98 FXSTS Front tire
Will the Softail Springer front end accept a 90/90-21 tire instead of the 80/90-21?
Old 12-08-2017, 06:12 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Red face
It's all down to rim width IMHO. I can't imagine that the slightly larger section tyre will cause any clearance problems. According to my favourite tyre brand Avon, the 80/90 needs a rim 1.60-2.15" wide, the 90/90 1.85-2.50" wide. 2.15" is popular, so if you have that size rim you should be fine.....
Old 12-10-2017, 05:00 PM
04 SE DEUCE's Avatar
04 SE DEUCE
04 SE DEUCE is offline
No, If bike is stock I believe a 90/90-21 can interfere and lock the front end. Local dealers son/service manager test rode a Bad Boy springer with a 90/90-21 installed. The front end locked when he went through an intersection with a fairly serious dip with an abrupt rise, locked the front and threw him down bending the front end. IIRC the dealer incurred no liability as the bike was unsafe due to incorrect tire size.
I'm ok with changing tire sizes if proper fit for the rim width and bike in question has clearance for full suspension travel.
There may be a kit for the front fender to change/maintain fender/tire gap as the front end travels, maintaining clearance...don't remember that's a ways back.
On an early springer I would use a MH90-21 Avon Cobra @ 38-40psi and enjoy the grip and steering.
Old 12-10-2017, 09:50 PM
Beemervet's Avatar
Beemervet
First OEM springer. Thanks for the reply, that's why I asked. The safety issue is the final answer.
Infamouz
Wheels/Tires
11
04-25-2017 04:10 PM
logic2
EVO
05-08-2012 10:36 PM
96SpringerSoftail
02-25-2008 09:05 AM
MotorUnit
07-23-2007 06:20 PM
RockDog
02-27-2006 11:48 PM
Quick Reply: '98 FXSTS Front tire
