2006 Softail Std 200 tire to smaller
Old 01-11-2018, 07:01 PM
sbrmike's Avatar
sbrmike
sbrmike is offline
Default 2006 Softail Std 200 tire to smaller
I have a 2006 H-D Softail Standard (EFI) with the 200 Rear tire and solid rim (factory I think).
I want to switch to a narrower rim / tire. What all is needed? I have the skinny belt. Is there a specific spacer kit to use with the narrower rim? Factory or aftermarket available? Recommendations please.
Old 01-12-2018, 11:22 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
200 sounds very wide for a stock tyre of that era. Stock rim diameter is 17" and a 200 tyre to fit that is likely to need a 6" or wider rim. Your owners manual will tell you what size the stock tyre is. If you don't have one you should be able to download one from the H-D website, via the Owners tab.
Once we know exactly what you've got we can be more helpful. It may also be worth posting in the Softail section, where you will find fellow Standard owners.
Old 01-12-2018, 12:43 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,235 Likes on 1,811 Posts
That's exactly what came on his 2006 FXST...a 200 on a 17x6" Rim.
I think that's when they started making the the wider Softail hubs. So you'll probably need a pulley spacer and some custom wheel spacers (at least the Left Side) to use the narrower hub and rim width 17x4.5" or 16x3" wheels from the other models
Unless you're looking for 16x3 laced spoke...they made those for the later softails in a Wide-Hub
Old 01-12-2018, 01:28 PM
sbrmike's Avatar
sbrmike
sbrmike is offline
That 16x3 laced wheel "Wide Hub" would be the ticket!
The dealership said a lot of folks switched from lace to solid because of the bigger engines loosening the spokes too much. I am north of 60 and not ripping the road like I used too. It would probably do me fine. I spun off many a riveted on sprocket on my '67 XLCH back in that era. I never had trouble with laced wheels on my various Shovels through the years. I really wish I still had a Shovel!
My bike came with 200 55 17 from the factory. I am not sure if the solid rim is original is all.
Old 01-12-2018, 01:35 PM
grbrown's Avatar
grbrown
grbrown is offline
Cool
Only 60? You are but young! Your bike when new, according to the internet, very neat:
Old 01-12-2018, 01:53 PM
sbrmike's Avatar
sbrmike
sbrmike is offline
Well this is what the old Flame looks like nowadays; I think a bit better than from the factory.
Old 01-12-2018, 01:59 PM
sbrmike's Avatar
sbrmike
sbrmike is offline
How's this for a perspective!
Old 01-14-2018, 10:53 AM
grbrown's Avatar
grbrown
grbrown is offline
Cool
Brilliant! Nothing has changed, and yet......
Old 01-17-2018, 09:43 PM
sbrmike's Avatar
sbrmike
sbrmike is offline
Old 03-08-2018, 02:55 AM
01HellOnWheels's Avatar
01HellOnWheels
01HellOnWheels is offline
ive got a set of custom powder coated stock size wheels.
21x2.15 front
16X3 Rear
Quick Reply: 2006 Softail Std 200 tire to smaller
