Front tire won’t hold air pressure
Old 05-26-2018, 06:30 PM
sctrcks17's Avatar
sctrcks17
sctrcks17 is offline
Default Front tire won’t hold air pressure
my commander II on my 17’ RGS keeps losing air pressure It has about 7,000 miles on the tire and I fill it to 38psi within a week or two it’s down to 15 to 18. Did a full shell leak test and no bubbles. Had the whole valve stem under water too. Any one else have this happen Rear tire is holding air even with a nail in it (crap my near new tire has a nail)
Old 05-26-2018, 08:31 PM
deadbroke's Avatar
deadbroke
deadbroke is offline
What pressure are you testing it at? When I test a passenger car tire I sometimes have to raise the pressure 20-25 psi above the normal running pressure to find a leak.
Old 05-26-2018, 08:36 PM
sctrcks17's Avatar
sctrcks17
Tested at about 55 PSI.
kel03's Avatar
kel03
kel03 is offline
Received 6,044 Likes on 4,356 Posts
As above says, it should show air leakage in a water test..........and get that nail out of the rear man, just asking for trouble.
Campy Roadie (05-27-2018)
Old 05-27-2018, 10:41 PM
rjacobs's Avatar
rjacobs
rjacobs is offline
soap it down...
I had a car wheel/tire that did it and water tank test showed nothing...
I soaped it up at the house and found the leak. About 5mm of the rim/tire was leaking. Either the wheel had a VERY fine, VERY small crack(not visible to the naked eye) or had a little corrosion on it and the bead wasnt seating as well as it should. I never did anything about it except add air every 2 weeks.
Old 05-27-2018, 11:48 PM
im's Avatar
im
im is offline
Is tire valve core tight ?
Is cap correct for valve and not touching valve core ?
Old 06-02-2018, 09:38 PM
Fatdaddy2's Avatar
Fatdaddy2
Fatdaddy2 is offline
Is that the dreaded "tread cracking" that I've read about on the Commanders?
Old 06-02-2018, 09:43 PM
sctrcks17's Avatar
sctrcks17
Never heard of tread cracking on these. But I never looked it up I didn’t see that on the tire tho. I’m guessing it’s the bead leaking maybe under pressure when I hit bumps on rough road ??
Old 06-02-2018, 10:32 PM
Solospec's Avatar
Solospec
Solospec is offline
Soap it up. Really check the valve stem and valve core.
Phil
Old 06-06-2018, 04:29 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,245 Likes on 3,623 Posts
The nail is probably leaking some air as the bike rolls.
Quick Reply: Front tire won’t hold air pressure
