21in wheel issue heritage softail
Old 06-14-2018, 10:00 PM
Jshad315's Avatar
Jshad315
Jshad315 is offline
Stage I
Default 21in wheel issue heritage softail
Hello everyone, just picked up a used 40 spoke 21in wheel to put on my 02 heritage. I bolted it up tonight and had an issue. If I use the stock spacers on their respective sides the rim is not center in the fender. If I switch the spacers it is center in the fender but the caliper and rotor do not line up.... I was wondering if maybe the rim can be dished a little to one side to make it work. Any help would be great
Old 06-15-2018, 08:30 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,228 Likes on 1,806 Posts
Can I assume the wheel you're trying to use is from a "Touring" Model (has provisions for Dual Discs)?...
If so, that's why it's "Off" and it's "Off" the Wrong Way...where when the wheel is centered, Material would have to be removed somewhere to allow for proper rotor-to-caliper alignment?
I think you move it over the little that it needs (Offset it more)...OR disassemble the wheel and have the Rotor Mounting surface milled the needed amount
megawatt
EVO
06-12-2019 08:32 AM
tsobash
08-03-2017 12:04 AM
eafxstc99
EVO
05-20-2015 01:31 PM
Dyna2002
11-28-2014 07:13 PM
Scrubdog
Wheels/Tires
04-22-2009 03:35 PM
Quick Reply: 21in wheel issue heritage softail
