Snapped bolt in caliper
06-19-2018, 08:21 PM
So, I was all excited to get my wheels back on, first time by the way, after getting new tires. I was torqueing the rear caliper and thought hmmm this is taking quite a bit. Just then, the bolt snapped. I then realized that I was also torqueing the bolt that holds the caliper together, there's three of them. Instead of the bolts that hold the caliper to the bracket. I tried drilling it out but it's not budging. How important do you thing the center bolt is? It's still in there. I think I know the answer so my next question is, how much does a new caliper run?
06-19-2018, 10:00 PM
I would try taking it to a local machine shop and see if they can get it out.
06-20-2018, 07:49 AM
Model and year of bike would help. A lot of us have changed calipers and extras lying around.
06-20-2018, 07:52 AM
2012 ultra limited. FLHTK
06-20-2018, 09:08 AM
Where did it break at? ... If you split the caliper into Halves would there be any "Nub" sticking out from the casting?
06-20-2018, 09:29 AM
I broke the center bolt. I never thought about taking the other two out. Would the caliper split into half if all three were out then?
06-20-2018, 10:08 AM
If the Head is gone on the center....then removing the other Two would allow you to split it...that's how you "Rebuild" Calipers
06-20-2018, 10:14 AM
Got it apart but the drill bit made it worse. I think I'm headedd to the dealer to buy a $200 caliper. Expensive dumb mistake.
06-20-2018, 10:22 AM
Do you have a Machine Shop or GOOD autor epair shop convenient? They should be able to get it out easily
06-20-2018, 10:30 AM
I'm in the Detroit metro area so we do have alot of machine shops but I think I messed it up too much. I may get a used one on eBay.
