Do I have to replace a tire that's been plugged?
Old 06-22-2018, 10:39 PM
blackxpress's Avatar
blackxpress
blackxpress is offline
I wouldn’t do it. New tires are a whole lot cheaper than hospital and funeral bills. I don’t even like running plugged tires on my cage but at least it probably won’t throw me in the ditch if one blows out. I had a motorcycle tire blowout on the interstate once. Thank God I wasn’t killed but it sure made a believer out of me. I won’t ride (or drive) on bad tires if I can help it.
Old 06-22-2018, 11:11 PM
Stopit's Avatar
Stopit
Stopit is offline
Received 1,021 Likes on 533 Posts
I was on my way home from a trip , 300 miles to go and got a puncher in the tread area, tire only had 1200 miles on it , just replaced it a couple months before. It started getting mushy on the slab so I pulled off. It was almost flat 200 feet from the off ramp , spitting ride -on all over. I plugged and monitored it to get home , it held a steady 40 psi all the way home, even 2 weeks later it was 40 psi. As much as I hated to buy another new tire I did , I also didn't worry about it once it was replaced , it was worth it to me.
Old 06-23-2018, 06:03 AM
touchdown's Avatar
touchdown
touchdown is offline
Received 1,659 Likes on 946 Posts
Hell no just buy life insurance
Old 06-23-2018, 06:12 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
As Yammy mentioned.
I have a tire machine and I patch a hole in the tread from the inside. I have a tire on one of my bikes right now that's patched from the inside; I'm just not throwing a good tire away. If an internal repair is done correctly, you have a better chance of dying because of high cholesterol.
The following 2 users liked this post by Campy Roadie:
twoglides13 (06-23-2018), Yamaharley (06-23-2018)
Old 06-23-2018, 06:39 AM
blackxpress
Originally Posted by Nomadmax
As Yammy mentioned.
If I ever get a hole in a tire I’m bringing it to your house. I wouldn’t be afraid at all to run one that was patched from the inside but I’d be scared to death riding on a tire with a plug in it.
Old 06-23-2018, 07:27 AM
BuzzCap7's Avatar
BuzzCap7
BuzzCap7 is online now
Moderator
Received 18,339 Likes on 10,703 Posts
I would my friend.
Tires are critically important. Even when just riding around town.
If u r having trouble making the $350 (I thnk u said), PM me, and I will help u offset the cost.
You don't screw around with tires. Be frugal elsewhere but not with tires. Your life is riding on them.
BuzzCap7
TSheff (06-23-2018)
Old 06-23-2018, 07:59 AM
Devilgear's Avatar
Devilgear
Devilgear is offline
Thanks everyone for your input. It's the back tire by the way. The $340 was at the dealership and the first place I called. I'll call around and find a better deal I'm positive. I'll get a new tire and be done with it.
Old 06-23-2018, 08:13 AM
86glider's Avatar
86glider
86glider is offline
As Yammy mentioned.
I agree with this,a small nail hole patched from the inside Imho will cause no effect on the integrity of the tire.Side wall is a different animal, and a no,Or you can tube it
Campy Roadie (06-23-2018)
Old 06-23-2018, 08:14 AM
BuzzCap7's Avatar
BuzzCap7
Moderator
Good decision mate. I strongly support that. And you know something DG my friend, to have "peace of mind" alone makes it worth it IMHO.
Way to go!! Enjoy it...........
BuzzCap7
Old 06-23-2018, 08:56 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,235 Likes on 1,811 Posts
Did this Thread start in another section and then get moved to "Wheels/Tires" ? ...just wondering...has the "Markings"
I'm glad for your mental battle that you're changing it (+ plus you do have 5200 miles already), but....
Yeah, it's a small hole in the thread...keep the air from leaking out...good to go
Quick Reply: Do I have to replace a tire that's been plugged?
