91 Sportster Wide Tire Questions
I got my frame guy to convert my sporty to a hardtail that will take a 200 wide tire. I found 21x2.15 & 16x5.5 60 spoke rims details below
FRONT WHEEL IS A SINGLE FLANGE AND WILL FIT FIT WIDE GLIDE FXST, FXSTC, FXDWG 1984-99
THIS IS A DUAL FLANGE WIDE REAR WHEEL FOR WIDE FRAME APPLICATIONS
- 1986-99 STYLE REAR HUB FEATURES A .900" EXTENSION TO MINIMIZE PULLEY SPACERS AND THE BEARING IS MOVED OUTBOARD TO PREVENT BENT AXLES
Ive measure all dimensions concerning internal axle width but cant find alot of information on if an offset hub will effect the position of the sprocket, i will be doing a chain conversion to fit it all in. After i get my rims i plan on measuring to see if a 4 under springer will give me lowest ride while keeping the bike level. Please help
