Avon Cobras Sans Balance Dot
I just installed a set of Avon Cobras out in the garage tonight and found they don't mark the heavy part of the tire. I have all my rims marked inside where the heaviest and lightest spots are so I know where to put the heavy part of the the tire (ie the lightest spot of the rim). So when you mount Avons (the Cobras at least) you'll need to put them back on the balance stand and move the tire around before seating the bead to minimize the amount of weight needed. Not a deal breaker if they turn out to be good tires (I want grip over wear) but it was the first time I ever ran into that.
Campy Roadie (08-02-2018)
Yes, the valve stem part of the rim is often referenced as the lightest spot. I check every wheel for the actual light spot and mark it; it's almost never the valve stem on Harley cast wheels. The dot on tires indicates the heaviest part of the tire so to minimize the amount of weight used to balance it the tire spot should be aligned with the light spot on the rim. At some point, I may come into the 20th century and use some internal balancing like Ride On or Dyna beads, maybe when I run out of wheel weights
Tired (08-02-2018)
Campy Roadie (08-04-2018)
