180 rear tire up front
09-02-2018, 03:12 AM
Anyone know about running a rear tire up front? Good or bad? Thanks
09-02-2018, 07:55 AM
Quote:
Originally Posted by
liscio42
Not a problem
Make sure the rim is wide enough for the Tire and REVERSE the Normal Tire Rotation (i.e. Mount the tire to run Backwards)
09-02-2018, 09:10 AM
Thanks, heard both sides of that question
09-02-2018, 09:11 AM
The confusing part was, they now make tires that will work either direction
09-02-2018, 09:20 AM
liscio42
What I've seen (referring to Heavy Cruiser tires), is they just add the additional "postion labeling" (e.g. "Front" in your case) which includes the Rotation Arrow pointing in the Reverse direction
The result would be the same as what I said in the post above.
09-02-2018, 09:50 AM
Here's a Pirelli Night Dragon GT ... it's indicating the direction when used as a REAR and then the other direction when used as a FRONT
09-02-2018, 10:02 AM
Yes, seen that one. That's the tire that made me question, thanks
09-03-2018, 05:08 AM
How about a front hub assembly for a performance machine wheel? Haven't had much luck finding one. Does Revtech still make them for late model, 2017?
09-08-2018, 11:34 PM
A 180 on the front would make the motorcycle even slower, and make it handle even more sluggishly, as compared to a smaller tire.
fogrider
05-13-2013 11:46 PM
jackhis
11-21-2012 10:01 PM
rcevil
03-18-2012 04:20 PM
Boom
05-27-2010 07:38 AM
Punky Brewster
09-19-2006 08:22 PM
