Hi, I have a 97 Road King cast wheel but the spacer in the middle looks like what came off a spoked wheel which was what came on it stock. Im wondering because I was looking at the parts breakdown on the Ronnies parts page(cool find) and it shows a different middle spacer is used if you have a cast wheel than a spoke. The cast spacer looks as if there are heads on the ends. Anyone know what this is?
thanks
... it shows a different middle spacer is used if you have a cast wheel than a spoke. The cast spacer looks as if there are heads on the ends.
If I understand you correctly, you may have reversed "what goes with what" ... Ronnies shows the one with "Heads" as being for Laced Spoke
Here's a pic of a similar Spacer Sleeve for a OE Steel Hubbed Laced Spoke (with "Heads" )... It approximately centers the sleeve in the wheel prior to axle insertion
