Wheel weights
Cwood8656 (01-22-2019)
Received 5,374 Likes
Cwood8656 (01-23-2019)
hd wheels are usually pretty good so that leaves the tire in ?. when i run across this on rare occasions, i will try marking the tire and rim, break the bead and slowly rotate the tire on the rim (deflated of course) and find the best position and the go about the weight business (inflate of course).
sometimes, you will not feel any tire issues but they usually will show up in wear patterns.
Hi all,
I like the ride-on for balancing. In your case you might want to use the "severe dose". You could use standard dose to start and see how it feels. Here's a link to their web page about install info and dosage.
Hope that helps..... goldie
https://images.ride-on.eu/en_US/dosa...structions.pdf
Received 6,044 Likes
