Retro looking tires
there are many outlets for vintage tires, just google, coker has some.
i can not say much about shinko tire. they had no issues with traction but i smoked them in 4>5k miles. the highest i ever got was a tad over 5k on the stock dunlop, running a commander now and if it does not pan out, going to the DARKSIDE!
So im fairly sure you don't have a square 21" front. Do you have any handling issues?
they do not recommend running an english tire (flat bottom) and the so-called ball bearing tires (mushroom sometimes). i hate the performance tires, good for curves but junk for flat running. there is 2" of contact vs 4.5" of contact. i can smoke a performance tire in less than 4k. they suck on wet pavement, i can break traction on a wet road at 70 mph. they say do not run bias and radial also although i have without issue.
i like the commander so far as it is pretty much a english tire and handles well in the curves without the fall-off feeling, only time will tell if mileage is good, if not, darkside i go!
