pulley bolts
I chase the female threads with a thread chaser or tap to make sure they are clean. Wire brush the bolt threads. If the bolts were not loose when you took them out, they should be fine. It's doubtful that the aluminium wheels would cause them to be over stretched. When a bolt is stretched to it's max, each consecutive reuse looses "clamping force" even though the torque wrench may be set the same each time. These bolts are not being stretched to it's max.
Loctite 242 is good for this application. 243 and 262 don't use on the wheels. 272 is OK, but not necessary.
