Big twin Vs. Sportster hubs
I swapped out my rear mag for a black, chrome laced wheel on my 96 XL Custom sportster. Now I'm looking for the matching front wheel and it's been difficult to find one with a single flange that is listed as being suitable for a sportster. So I'm trying to figure out if the FXST and FXDWG hubs were the same width as the sportster hubs in the 90s?
Here's the wheel I'm wanting to get, I just need to be sure the wheel will easily swap in: Front V-Factor Wheel
thanks for your responses
Received 4,925 Likes
Yeah ... not even close ... about 2" difference in width
You want 21"? ... If so, the correct V-Factor wheel is a #51676
https://www.ebay.com/itm/BLACK-21-40...oAAOSwwnVc3yZ2
The"Stock" Photo is NOT correct, but the wheel is
Here's a correct photo, but more expensive ... same 51676 wheel
https://www.ebay.com/itm/40-SPOKE-BL...YAAOSwzd5cjTve
BE AWARE. This from V-Factor ...
* When replacing models equipped with 19" wheels with these 21" wheels you must mock-up wheel without the tire mounted and check for wheel spokes to brake caliper clearance. If wheel spokes contact the brake calipers, you must purchase custom shallow brake calipers.
Shovelmad
07-31-2017 02:12 PM
