Dyna Rear Wheel Removal
Great write up especially with the pictures. One question though. Do you know if the V notch has to be positioned and if so why? My spacer fell off before I saw the positioning. My right spacer has the notch facing the brake caliper arm like you show in the picture, but it is oriented different than yours. I am still curious about that notch, especially since I couldn't see anything mentioned in my manual. Thanks again.
On a 2003 it's better to let down the exhaust to allow access to the bolt for the axle. (yes, what was Harley thinking when they installed it in this direction) Then remove the cotter pin on the nut side. Support the bike and the rim and pull the axle. Lift up the bike a bit further to let the tire out from the rear fender.
