When to Replace Brake Fluid?
Old 02-09-2009, 10:10 PM
NYSportster's Avatar
NYSportster
NYSportster is offline
Post When to Replace Brake Fluid?
Manual says to check levels and I am assuming if it's low to add more brake fluid. So when do you need to replace brake fluid?
Old 02-10-2009, 05:25 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Uncle Scrooge is offline
My manual says every two years. I thought this was overkill but I tried it. New fluid did make the brakes feel firmer.
Old 02-10-2009, 06:43 AM
sniper77's Avatar
sniper77
sniper77 is offline
As often as you like but at least every 10K in my opinion.
Old 02-10-2009, 07:38 AM
rmc115's Avatar
rmc115
rmc115 is offline
Depends on what fluid, if its a dot 4 based bike every 2 years because of water absorption. Dot 5 dosen't pick up water so not as critical. Mike
Old 02-11-2009, 08:50 AM
NYSportster
Thanks. My bike uses DOT 5; I'm gonna change it in the Spring.
Old 02-11-2009, 10:38 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
10k/2years...flush the entire system...get some speed bleeders and it takes 10 minutes.
Old 02-11-2009, 03:19 PM
Black Bart's Avatar
Black Bart
Black Bart is offline
Where, pray tell, may find some speed bleeders? And, what will they look like?
Bart
Old 02-11-2009, 03:37 PM
rbabos's Avatar
rbabos
rbabos is offline
How many actually change brake fluid in their cars? Havn't done a single car in my 40 years of driving. Unless major work is done, it aint needed. It's a none compressable fluid and don't change. It can't absorb moisture in a close system unless you drive around with the cap off as it's not vented to atmosphere. There is nothing special with a Harley that needs periodic fluid changes.
Ron
Old 02-11-2009, 08:19 PM
Dalton's Avatar
Dalton
Dalton is offline
Ron
Whew, I thought I was the only one that didn't change brake fluid.
Ron, you are right on the money. Brake fluid does not deteriorate unless contaminated. DOT5 does not absorb moisture. I am an old auto mechanic, hotrodder and bike builder and in all my years I have never just changed brake fluid as a maintenance item.
An for the guy that said new fluid made the brakes feel better, you cannot compress a fluid, no matter what it is so you must have had air in the system that you bled out thus making the lever stiffer. And for the recommendatin at every 10k miles - hell, I would be doing this twice a year !
Old 02-11-2009, 09:12 PM
rmc115's Avatar
rmc115
rmc115 is offline
Ron
Ron, the systems are not completly sealed and dot 4 absorbs water and the problem with that is all the metal parts corrode. Nowadays most cars have a $1000 abs pump/module assy that wont tolerate any corrosion. I've replaced plenty on vehicles that haven't been maintained. Dot 5 is not norm in cars. Cheap insurance. Mike
Quick Reply: When to Replace Brake Fluid?
