ABS Stainless Steel conversion
I'm hoping some of you out there with 2007 FLHTP may have found away to do this conversion. My 2007 Cop Electra Glide has the ABS with stock lines. Can I change over the Front and Rear brake caliper lines with Stainless steel one from the 2008 SE Electra Glide Touring model. In 2008 the FLHTCUSE went to a redesigned ( smaller) ABS unit but the Main lines should fit shouldn't they.
This is the down side of having a COP HD it isn't a civillian bike so some of it is the same as standard some of it isn't. It lives in two worlds.I can't find any standard lines in the catalog to fit it due to it having ABS.
Has anyone been able to switch over to sS brake lines with the 2007 cop Electra Glide ?
Thanks
Chuck
