Slime in Tires??
Slime in Tires??
What preventative measures are you all taking to protect your tires from flats?
Also, do you carry a hasty repair kit with you?
I carry an assortment of crap that I call a "tire kit" for my car and truck, but with no storage space on my nightrain, I was wondering if sliming the tires is a pretty good idea and won't be harmful??
I've used slime in small, low pressure tires where balance is not important such as a garden tractor, pull behind mower, wheel barrow, etc. It take a substantial amount to plug even the smallest hole cause by a thorn. It also dries out over time and I have to add more to reseal the same puncture. I would never use it as a preventitive measure in a high speed tire where balance is important, especially a motorcycle tire were pressure and balance are critical.
Caveat to using "slime" in motorcycle tires
You might want to check with your tire's manufacturer about what their warranty policies are regarding the use of tire sealants. As far as I know, pretty much all of the majors frown upon the use of them and in fact their use will void their warranties. Just saying.
Cheers
Cheers
Been Considering Ride and Go even bought the kit for the next change .. But not until hear some first hand feedback from it beside the biased report from the company that makes it .. It's pretty heartbreaking to have a flat when have less than 1,000 miles on the tire which happened to me the last tire change ..
Cheers
Cheers
