axle hole?
Old Sep 4, 2011 | 01:57 PM
mang0's Avatar
mang0
Default axle hole?
I was just reading a thread regarding centering afront tire and now i am wondering if i had done mine correctly. Another person had posted that the hole in axle should be flush with the leg, as this centers the axle
The 2010 manual never mentions this. it says install slider cap (do not tighten at this time) and tighten axle nut to 62-67 ft lbs. "hold axel stationary with a steel rod or screw driver inserted int othe hole....while tightening" then tighten axle cap (rear first).
as you can see in my pic, my hole is not flush with the fork leg (off about 1/8 in) Are others flush ...?
Old Sep 4, 2011 | 05:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Your manual gives the correct procedure. If you did it exactly as the manual says, you are good.
Old Sep 4, 2011 | 07:48 PM
mang0's Avatar
mang0
thanks
Old Sep 7, 2011 | 09:29 AM
grbrown's Avatar
grbrown
Talking
Looks fine to me. If I call round will you clean my bike so it looks like yours?!
Old Sep 7, 2011 | 10:59 AM
ajayrk's Avatar
ajayrk
Been across this myself. Late models don't use the hole for alignment. Let the slider seeks its neutral position and just tighten it up.
Is "axle hole" a way to sneak by the sensors?
texashillcountry
EVO
29
Jul 16, 2014 07:35 AM
chunks
Apr 8, 2012 12:57 PM
2010fxdwgrider
Jun 26, 2011 06:24 AM
Hinzy
Sep 13, 2008 12:51 PM
hawg03
Jun 2, 2007 10:59 PM
