Balancing Beads - A Real Life Test
#41
THE dot on tire , to put at valve stem does the trick for lots of people .
#42
#43
#44
JIM
#45
am using the very tiny beads , 2oz each wheel , and now 3oz each wheel , and 2 brand new Dunlop American elites .
#46
Yes I have them in my metric spoked tubed tires. And another method of putting them in is compressed air. Remove the stem valve on tubes or rim fill clear bead insertion tube almost full then use an air nozzle and blast em in. Mind You this method is only something I have read someone uses. I have not proven it out. I do plan to though soon enough. I have a new set of tires coming for my Glide and have all beads and tools to change the tires myself. Gonna give it a go.
#47
beads suckj just did my 07 bagger , new tires , and beads , 90 on nice turn starts to wobble ,, starts wobble approaching 100 on interstate , using weights 114 firm like at 80 , taking beads out and going to try NO weights or beads ,
JIM
balance, balancing, bead, beads, counteract, counteracts, forum, harley, jpmagazine, memory, motorcycle, motorcycles, reviews, test, tire, tires
