Wheel bearing size on 2001 Touring bike
I picked up some stock HD mags, and, the rear wheel has 1" ID bearings.
I believe I have a 3/4" rear axle, on my 2001 Road King. At least that's what Ronnies OEM parts finder shows, when I look up the bearing part number.
Questions:
Should I install 3/4" bearings in the rear wheel, or buy the 1" axle, spacers, etc, to go with the new mag wheels?
When HD changed axle sizes, the wheels didn't change, did they?
Here are the wheels I picked up:
Questions:
Questions:
Questions:
http://www.wjbbearing.com/ The PN for WJB is DH559339 or you can also use the All ***** 41-3206 or KML 1013-2RS.
I have not used the bearing reducers but will be trying out a pair on a front wheel change to my Deuce. From what I read, they should be fine. An adustment to the outer spacers will be required to adjust for the thickness of the reduce flange.
This weekend decided to try something similar. I have an 89 Ultra with 3/4" axles and just picked up some 06 wheels. I was trying to find bearings that didn't come from the local HD shop, not because of the price, but rather than when I called to see about getting 3/4 bearings for those wheels and told them my project, the guy told me everyone there says that it isn't going to work. One of the reasons that they said that it wouldn't work is because of rotor and pulley placement. I told them that I bought the wheels with rotors and pulley and from what I measured, everything is very very close. THEN THE HARLEY DEALERSHIP PARTS GUY TELLS ME THAT IT STILL ISN'T GOING TO WORK BECAUSE THE ORIGINAL BIKE, MY ULTRA, IS A CHAIN DRIVE. At that point I knew that he has no idea what he was talking about.
So after much research I find the bearings that I need are the 9267 bearings. I find the Chinese made WJB bearing dimensions and find a suitable cross.
Fafnir (Division of Timken) P/N: 205KRP2AG
Has anyone used these bearings before. They are available from Allied.
Farnir has a good rep but I wouldn't necessarily be afraid of a bearing just because it is made in China.
If I were you, I would buy a duplicate set because I suspect you will be mocking up the install several times to get the outer spacer dimensions correct. This may require pulling and re-installing the bearings several times. Use one set for the mockups and the other set for the final install when they won't have to be removed again.
Also remember that you are doing a "custom" install and you can forget what the service manual says about bearing install. You will have to install what works.
BAD advice above!!! You can NOT use the 1" bearing spacer with 3/4" wheel bearings!!!!! Why? Simply because the OD of the inner race is basically 1". This means the inner bearing race will not ride against the spacer as it's suppose to, but rather will simple tend to 'creep' inside the spacer.....which renders it useless! Further, it means the bearings are being loaded by the axle nut tension instead of being 'un-loaded' by riding against the spacer. This will lead to bearing failure!! For the record, on those Airstrike wheels listed above, the same 1" wheel bearing that came in them has the same dimensions as the sealed 3/4" bearing. So, with the proper spacer, which I believe is 4.812" long, has a 3/4" ID and a 1" OD.....(which is also the same width as the 1" bearing spacer....but that spacer has a 1" ID and a 1.25 OD)....those wheels will fit an '01. You can NOT use a 1" axle on the '01....the entire swing arm is different between '01 and '02 when the MoCo went to the 1" axle. Remember that the 1" axle has the built-in belt tensioners that also 'align' the rear wheel. You still have individual wheel alignment / belt tensioners on your '01. Simply 'not' interchangeable. Sorry to say this, as I too have an '01 Road King and I'm about to put these same Airstrike wheels on my bike. WC
