What Are These Connectors
I'm having a very hard time with this picture. I'm installing heated grips on my 2023 lowrider ST and cannot find this connector in the wiring diagram. Can you tell me which diagram it is in? I have had the wiring out of the cavity in the frame and did not see this connector. Do I need to dig deeper into the frame? It looks like it comes from the front of the motorcycle, not coming from the frame, Please explain.
So what part of the circuit is the heated grip connector in the frame? I put my heated grips on and they work fine... But I ran my own power up front. Harley says you need accessory wire harness to battery for more connections. I did that, ran power up to heated grips, but then still had to splice/plug into connector in frame.
Isn't that the pre wired part in right grip? Run power up to left grip connector. Second connector on left grip runs back to connector we are discussing in frame. And that is the pre wire part to right grip because all you have to do for that is put on and plug in the wire in the bar already?
I had it figured out when I did it.
You need to pull out the large rubber grommet where all the wires from the handlebars dive into the frame. I found it was easier to remove the front tank bolt, lift the front of the tank up and put the bolt back into the tank to rest it elevated on the frame. You don't need to remove the entire tank, just tip the front up a bit.
Finally found the mystery connector#1 and it is the Purge Solenoid. The plug must have been missed at the factory or may have inadvertently disconnected, who knows...
