2024+ Touring Models Discuss the currently offered Touring Models
'24 Streetglide Carplay
Old 04-27-2024, 02:06 PM
billbrummett's Avatar
billbrummett
billbrummett is offline
Default '24 Streetglide Carplay
So after shutting off engine, my yeti headphone device reconnects on startup. But the iphone doesn't. I have to go in manually and reconnect phone, then punch carplay .....any ideas?
Old 04-27-2024, 04:28 PM
billbrummett
come on guys, does your carplay reconnect on startup?
Old 04-27-2024, 05:38 PM
ASU-HD's Avatar
ASU-HD
ASU-HD is offline
My yeti device will connect first and then my iPhone connects. Sorry haven’t had the issue of the phone not reconnecting on start up. Maybe try unpairing and repair the phone?
Old 04-28-2024, 05:53 AM
Hasher's Avatar
Hasher
Hasher is offline
It’s totally random for mine. Sometimes it connects, sometimes it connects then crashes, sometimes it restarts my phone then all bets are off until I stop and unlock the phone. Sometimes it will stream music but won’t start CarPlay.
‘It’s truly a marvelous operating system, Harley should be proud.
Old 04-28-2024, 06:49 AM
GeneseeGap's Avatar
GeneseeGap
GeneseeGap is offline
What a great photo! Is that you stretched out in what I assume is a rest area?
And I second the operating system. I do not have all the updates but I have had only one issue that was resolved.
Old 04-28-2024, 08:08 AM
Roadie13's Avatar
Roadie13
Roadie13 is online now
Received 1,015 Likes on 501 Posts
FWIW, I just switched to the Maedhawk recently. It's worked well most of the time but occasionally CarPlay won't automatically start after restarting the bike. When I was using the 50S that came with the bike it connected every time. It wasn't always the fastest, but worked. Switched to the maedhawk because it's smaller and never has to be charged. Unless reliability becomes a regular issue I'll stick with it. For $18 it works good enough, but can't help but think a higher end unit may take care of some of these issues. Sometimes we get what we pay for.
Old 05-02-2024, 08:17 AM
bradleys's Avatar
bradleys
bradleys is offline
What are you using for a headset? Is that connecting seamlessly for you?
The only time I have a problem with CarPlay not starting automatically is when the headset has troubles. I use the mediahawk hack.
Old 05-02-2024, 04:12 PM
Hasher's Avatar
Hasher
Hasher is offline
Yeah, first year at Sturgis/Buffalo Chip, about a hundred miles onto the ride home and first sleep in a week LOL!
Old 05-03-2024, 09:07 AM
ChrisHo's Avatar
ChrisHo
ChrisHo is offline
Received 4,331 Likes on 1,344 Posts
Only times I have issues with Carplay starting are all on the phone. Each time it happens when I try to use my phone it is a black screen locked up. Disconnect from the bike interface and the phone works suddenly. Usually unlock phone then let the bike grab it and it works. Otherwise its called cycling the connect of the phone on the bike device manager while riding until the phone decides to work.
Normally it just all works at start up, first headset then phone
Old 05-04-2024, 01:28 AM
Frirish's Avatar
Frirish
Frirish is offline
5th Gear
Same question here. I can’t get my HJC (Sena) 11B to connect to the bike
Quick Reply: '24 Streetglide Carplay
