Unable to pressure up air shocks
2012 Harley Limited......
previous owner removed stock air shocks and replaced with coil.....
and then switched again before trading it in..
Now I am unable to get any readings with my air gauge...and system will not air up
all connections seem to be in working order
suggestions?
Thanks
Cajun
suggestions?
Thanks
Cajun
If you're using the Harley pump, I have found mine to be VERY temperamental getting the exact position of the valve and even the angle I hold the pump. Sometime, if the connection to the stem is canted, I do half a pump, the gauge pressure shoots up and no air flows to the system. Try keeping the angle as straight as possible and maybe shifting the pump a few degrees at a time. Real PIA. Good luck.
@Krobinson , can’t say whether it’s the valve or pump that’s unique, but a generic air pump will leak all the pressure out before you can get it disconnected. It may not even open the schrader valve in the first place. You do really need one of those special hand pumps. They’re about $20 on Amazon.
The shocks aren’t typical air shocks, so the bike isn’t going to jack up or anything as you add air.
