Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Where to buy air ride quick release fittings?
Old 04-23-2014, 01:45 PM
jcallesano's Avatar
jcallesano
jcallesano is offline
Default Where to buy air ride quick release fittings?
I have the hi-lo air ride system on my 06 night train...
The fittings are all metal and id like to replace the release valve on it.
They are fittings that you push the plastic tubing in and you cant pull it out unless you depress the ring first. I think they are push to connect fittings or quick release fittings. Regardless of that, I need to know where to find these fittings online. I cant seem to find the exact ones that are on my bike for replacement.
I was wanting to find a bracket that bolts to the rocker box with an air gauge and wanted to fab up a new release as well. Right now the release just rests on top of my oil tank and I dont want it there. (Kind of like this gauge mount, just want it smaller since my "ON" button is already custom fitted into my dash panel.)
Attached Thumbnails Where to buy air ride quick release fittings?-0987654321.jpg   Where to buy air ride quick release fittings?-photoid618.jpg
Old 04-23-2014, 05:54 PM
Lakerat's Avatar
Lakerat
Lakerat is offline
Old 04-23-2014, 05:57 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Any semi truck shop will have them as well as any good Napa auto parts stores.
Old 04-24-2014, 10:18 AM
jcallesano's Avatar
jcallesano
Originally Posted by Lakerat
MSCdirect.com HBU - Scott
Unfortunately, we do not carry a pressure release push to connect. Any brand or number on the fitting?
W T F cant find a damn fitting anywhere.
Old 09-04-2014, 12:07 PM
frankegd's Avatar
frankegd
frankegd is offline
I was able to find 98% of all the fittings I needed on Amazon. Did some research on some vendor sites, then searched the part# on Amazon. If you go that route, make sure you get them all, or the majority, with free shipping over $35.
Worked for me. I searched for 'push to connect 1/4 OD' (= my hose size). Shows a huge list and eventually the fittings I needed, plus some...
There are also the connectors from SMC, they are made out of plastic, but have the same specs...
I hope that helps.
FrankEGD
Old 09-07-2014, 06:14 PM
clinkous's Avatar
clinkous
clinkous is offline
6th Gear
Agreed. If your not in a hurry Amazon is the way to go. Also, Google search hose supply or hydraulic hose shop in your area. Most towns have one that all the contractors use but isn't well known to the general public
Old 03-17-2022, 08:25 PM
Colt357$$'s Avatar
Colt357$$
Colt357$$ is offline
Stage III
Default Please help
Are using your old release valve? I broke mine on my legend air ride and they won’t help at all
2gunslefty@gmail.com
ill buy your old ones or if you could help with some part numbers
Old 03-17-2022, 08:27 PM
Colt357$$'s Avatar
Colt357$$
Stage III
Default Please help
I have a legen air suspension and the air release valve and chrome button broke, does. Anyone know a replacement part number or have one I can buy please?
Old 03-17-2022, 08:42 PM
kel03's Avatar
kel03
kel03 is offline
Received 6,044 Likes on 4,356 Posts
Maybe PM him, his post was in 2014. Good luck with your search......some one may know of the parts though.
Hacksaw550
2014-2023 Touring Models
01-23-2019 11:35 AM
glideridemike
08-24-2018 11:52 AM
kustom78
11-29-2016 11:58 AM
RickK
04-30-2014 01:42 PM
DR. V-TWIN
05-05-2010 12:48 PM
Quick Reply: Where to buy air ride quick release fittings?
