My 2005 Screamin Eagle After upgrades installed
In front of my house
Wards Cooling fans, lockable glove box doors
Inner fairing shot showing HD1BT radio and Garmin Mount over Harley Dash Pad, used stock speaker grills over Polk MM651 speakers
Panacea LED tail and signals in smoke
Right side view
2005 CVO Electra Glide
New trim rings
New trim rings with new Windshield
Inner fairing and Windshield shot
More inner fairing
Dash pad top with Sirius XM antenna
From the back
Finally got nearly everything done. Installed Jensen HD1BT, Soundstream 520D amp, inner fairing dash pad with Garmin Zumo fairing mount, Satellite Radio add on (antenna on the dash), visor trim rings on spot lights and headlight, Wards Cooling Fans (black), Panacea smoke lay down LED tail light and turn signals and I still have some mini boards with longhorn mounts to put on. I took the tour pak off to ride around locally so it isn't on in these pics, but I there are some pics with it on in my photo album. I also got the lower fairings put back on (they were off when I bought the bike). There are several pictures, hope it isn't too much.
Mounting the crossovers for lower fairing mounted MM651's is a PIA. Won't fit in the bucket, so you have to hack the Polk harness up, and run 2 sets of wires to each speaker. I would suggest a pair of Infinity 62.11's. No crossovers and sound at least as good, but the grills won't work. I used the old Polk grills over mine (after Polk stalk failure).
I am trying to remember how I mounted them about 3.5 years ago when I had my last eagle electra glide. If my memory serves me right, I mounted the crossovers under the bucket but could not fully open the vents afterward. It worked fine that way. Never had stalk failure on any of the polks, however I am sure it happens.
