Correct me if I'm wrong
My neighbor just got an 11 cvo rg,and he's finally come to the conclusion that I'm a lite more knowledgeable than he on with motorcycle stuff. Right now it's all stock, he just ordered dresser dual and turn downs. So I'm trying to tell him his radio won't be **** and he wants to remove his tour pack which means the amp had to move anyway.. So I have a few easy questions..what all is different from rg to sg. From reading I've noticed some people do and do not have problems adding 6x5 in the rear pods, "he still wants to upgrade for when the wife is riding". I also think I've read on here that the BT 7.1s won't fit in the rg fairing, and I'll have to mount the amp on the side of the fairing instead of on the radio correct? Money isn't an option for this guy's but he's not gonna go to BT, he will prob get the same speakers, head unit as me and the RZ42000D..
Unless the CVOs have something different going on in the fairing, the BT 7.1 will fit in there for sure, it's tight but they absolutely fit. I believe the only RG issue with 7.1s up front are the 15 models.
I had a 4180 amp in mine and swapped to a 2180 after I decided to stick with a 2 speaker setup. There's only a couple of spots the 4180 will fit and it has to be oriented perfectly to not interfere with the outer fairing and is a PITA - bring a big bottle of patience and cover the kids' ears because you're gonna invent some new cuss words. BT is working on a bracket for the RG, Bill sent me some pics and they had prototypes available several weeks ago, give them a call it may be ready to go by now.
The 2180 fits no problem on a bracket. When I talked to the guys at BT they said they've heard of guys getting a 2180 mounted on top of an aftermarket HU in a 13 and down RG. I tried a dry run with the 2180 on top of my Kenwood HU (mounted as low in the faceplate as it could go) and just didn't feel comfortable with it - very close but no cigar for me. I don't know much about the size of other amps, there might be one that fits but I'm not aware of it.
Last but not least, make your buddy get the new head unit inside the inner fairing himself and then take it from there. I can't believe the fairing flexed enough to get the new unit in there. Scared the living crap out of me waiting the hear the fairing break......
