Looking to upgrade Boom system with R/F tm400x4ad
As my profile states, I have a boom amp, lid speakers and, I think, stock fairing speakers. As you might guess, it sounds ok, but, not great. I have no clue what speakers are in my fairing. I really didn't know what to ask for, when I purchased my '15 SGS. After putting over 5,000 mi. on the Odometer, I've grown to long for a better sound. A buddy of mine mentioned the aforementioned system, but, with a slight alteration to mounting system within my fairing. I was very hesitant on cutting on my new ride, so, I passed. Last weekend, I was at Eastern performance, and they too, recommended this set up. I never mentioned my buddies suggestion. So, I've decided to do the upgrade. My questions are: has anyone else done this same set up? The speakers are 6 3/4". If so, how much altering is needed? Last, both of them recommend I keep the boom speakers already in the lids, until I kill them. When I do, what 5x7's are the best choice? Anyway, thanks, in advance, for your inputs.
Haven't used the Fosgate speakers but I have used a TM400x4ad and I loved it. You have plenty of options for mounting it, yaffe has a mount specifically for that amp.
The Fosgate stuff is what yaffe uses in all the bagger nation setups take that for what its worth, haters will always hate
I thought I saw a thread a few weeks ago with someone installing those speakers, maybe search and see but they should bolt right in. If you have any rubbing you can always add the biketronics adapter rings, they give you a little more angle as their wedge shaped.
As for the rears, well you have so many options it all depends on how much you want ot spend and what your searching for in terms of sound.
Welcome to the madness, I don't think it ever ends
If you're gonna go with the High speed Rockford Fosgate amp IMO it deserves better speakers than the Rockford T1675's. They are "Okay" but will not blow you away. I've had and installed these speakers a few times. The Polk MM651's sound better than these speakers. If I were you I'd go with the Focal KRC's in the fairing and when you get ready to switch out your 5 x 7's go with the JL C5 570x speakers. They are the best sounding 5x7's I've ran across and I've pretty much tried em all. If not the 5x7 JL's the 5x7 Biketronics Hat's or the Infinity Kappa 682.11cf speakers. That's my .02
Bafflingbs (04-30-2016)
Do you have the Boom 5X7's? I'm trying to think back, but I think those are bi-amps for the woofer and tweeter with no passive crossover. I believe those are crossed at the two amps. So if you try connecting them to a regular amp it wouldn't work. Double check how those are connected to the Boom amp.
Agree with Gann. That amp sounds pretty damn good, but there is better speakers out there.
Yeah That!
Hopefully he rips all the BOOM stuff out of there and starts from scratch.
I've checked into some of these speakers that were suggested, and they don't seem to work with my '15. Am I wrong? Also, are these all water resistant? Those JL's look good. As do the Focal's. I read some reviews, and no one said they fit beyond '13's. Crutch field says these don't fit. Do they? And are they direct fit? If so, I'm in! Thanks again.
First off, agreeing with Gann and Haze about the amp and speakers...
Second, you have 5x7s that come from HD. You can run 6x9s and have been using adapters from Vtwin for my customers (I'm not a dealer for them, but have been happy with the product). They'll easily let you bolt up any 6x9 to the factory lids.
Let me know if you need any pricing on anything my man, I carry every brand.
I saw previous posts by others that have done that modification. Sounds kind of tricky. And, I'm afraid of losing the water resistance I have now. My buddy was telling me that RF is about to come out with a direct replacement 5x7 that sounds promising. I know it won't have the same sound, as a 6x9, but, I don't want headaches either. I will keep doing research on this topic, for when the day comes that I kill the boom ****. After all, it's only money
