Tuning With AVC
No depending on the amp in use some change as the power input voltage increases from running and aux position so does the audio output voltage change
the avc is activated by the wheel speed sensor.
I did do some testing this past spring and the voltage output jumps very aggressively depending on what stage you have the AVC set on 1 thru 4
eggwhite93
Audio Systems
21
06-25-2019 09:17 PM
